Canon iR ADV C3530i II - ADF Problem
  • luis1984bol
    • Nov 2011
    • 155
    [Misc] Canon iR ADV C3530i II - ADF Problem
    Hi Techs:
    I have a problem with the ADF in a Canon iR ADV C3530 II.
    This message apperars when I turn on the machine. NO ERROR CODE. The FEEDER option in SERVICE MODE disappers.
    I replaced the ADF-PCB and flex cable.
    Can anyone please help me with that. THANKS.
    This gallery has 4 photos.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Check the error code in service mode.
    copier-display-error
    • luis1984bol
      • Nov 2011
      • 155
      There is no ERROR CODE.
      Just that message in the panel control.
      • zoraldinho
        • Mar 2008
        • 5018
        Press the copy icon and try to make a copy.
        It should show an error code.!
        • luis1984bol
          • Nov 2011
          • 155
          Yes. I did that. It makes a normal copy from the glass.
          • zoraldinho
            • Mar 2008
            • 5018
            It's probably an error for the flat cable scanner or shading value. Maybe Error 280 or 302. I haven't seen it display the service key, but no error code.
            • duwaynebrooks
              • Aug 2015
              • 48
              Hiya
              You need to jump into service mode and check for the error code.
              Did the ADF work before?
