Machine can't boot up
  • Ronie69
    • Mar 2022
    • 7
    I have Image Runner 323K model, when I power on the machine the hardware initialize but the progress bar in the display of the control panel hang up. It will not go to ready state. I already replaced Main Controller PCB together with SO-DIMM (Image Memory). But still problem persist. I re connect all jack from DC Controller and Reader Controller still it won't boot up. Is there any one encounter my problem? What should I do next. See attache picture for your reference. Thanks for the help.
  • Obtex
    • Jan 2017
    • 22
    Re: Machine can't boot up
    I`ve had this issue 2 times on similiar copiers, both times it was the disk drive (hdd)
    • Ronie69
      • Mar 2022
      • 7
      Sir Obtex,
      IR323k same model of IR2525 have no Hard Disk (HDD). The booting of machine come from Main Con PCB and Boot Rom PCB.
        • 37422
        You might get more Canon techs helping you if you had posted it in the Canon technical forum, https://www.copytechnet.com/forums/canon/
        • Ronie69
          • Mar 2022
          • 7
          Sir slimslob, thank you for the info.
