Canon IRC7260 leaking developer starter
  • OscarL2154
    • Sep 2020
    • 1
    Hello Friends. I have a Canon ImageRunner Advance C7260. The machine is spilling/leaking cyan developer onto the IBT belt and into the fixing unit. I have replaced the Cyan developer assembly 3 times and the machine still spills the developer. With all the developer getting down into the lower assemblies, it is throwing all kind of error codes. Anyone ever had this scenario happen to them before? I could use some advice on how to resolve this issue. Thank You in advance.
  • derrekflo
    • Feb 2022
    • 40
    Re: Canon IRC7260 leaking developer starter
    the developer unit is incorrectly assembled, check it.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      Can be bad DC con.Check developer values.
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        Also when the drum wears it can start pulling dev. Always keep old dev units for the starter so you can top up the dev when it gets low....they barely fill these with enough from factory.
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
        • 20 year tech
          • May 2014
          • 577
          Plus 1 on this reply, I normally replace the drums with the developers for this reason.
