Canon IR Adv 4225 Scanner Issue
  • sudeep
    • Mar 2020
    • 3
    [Misc] Canon IR Adv 4225 Scanner Issue
    Hello
    There is problem with Canon IR Adv 4225 model, after resetting machine its X and Y are misaligned, I tried to Adjust X and Y but not get desires result (ADJ-XY).
    Problem is all side edges are cutting in A4 almost 3 mm in Scan as well as in Copying. But When I scanned in A3 all edges area are covering. It is old Reconditioned Machine and its body Serial number is different than it is showing in Machine Service mode that's why front door values are not working. So I want your guidance to solve this issue and this is serious issue for me and I had tried scan with other Canon machine they are covering whole document in A4.
    I am attaching scan image of A4 and A3
    A4
    A3
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Canon IR Adv 4225 Scanner Issue
    Reset? How?....did you backup dcon?
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • giogi
      Engineer senior
      • Jan 2016
      • 181
      I think these are the normal white areas around the image.
      each printer has 2.5mm white on each side
      however try changing the item COPIER>ADJUST>BLANK
      "Knowledge is a source, but unfortunately ignorance is a sea."
      • sudeep
        • Mar 2020
        • 3
        I get one temporary solution with Erase Frame option by default it is 4mm I reduce it to 1mm then I get desired copy result but it has one draw back when I set frame option to 1mm then 2 in 1 copy feature get disable.
