CANON IMAGE C6800- web reset
  • hudson14
    have error code E0005 for cleaning web . replaced web but cant get code to clear. tried * 2-8 * but screen locked on error code. copier not networked. do i need to be connected to pc to clear code and reset counter. manual no help there. any help appreciated.
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    You need to reset in service mode.
    If you leave the machine in error for too long you won't be able to access service mode.
    Cycle the machine off/on and let it go to the error code again then try service mode>Copier>Function>Clear>Err
    Don't forget to clear both counters for the web
    • rosaro75
      • Mar 2009
      • 87
      *28*> copier>counter> drbl1>fix-web select and press clear to reset web counter.
      in this fix_web may in drbl1 or drbl2.
      and also it causes due to sensor in web assembly. cheak interrupter position. the web may cut or unwinded.
