I just got a Canon c3220 yesterday. The print quality looks good as far as the drums but all 4 color (cmyk) all print about 1/32" off from each other in the direction the paper travels. I checked the itb and cleaned it & its rollers with alcohol & a cotton pad removing some toner but not an excessive amount. I local tech told me to go into the service menu & had me reset a few things. Now when I turn on the machine I do not see a tab for PRINT, all I see is 3 tabs COPY, MAILBOX & SCAN...PRINT tab has disappeared. Can anyone help me get it back. The machine has an ImagePass C1 on the back. I also need help getting it connected to my 10/100 ethernet switch as a TCP/IP connection. I am affraid the service people I talked to on the phone told me to do something that has screwed it up. Also as far as registration problem I was told it could be 1 of 3 things, first the transfer belt or itb which I don't think is it because registration is consistent but all out equally about 1/32", second they said the laser may need to be recalibrated (can anyone tell me how to do that?) and third it could be a board problem...most machines I have worked with have a utility in user mode or service mode to adjust each color to get registration. I am on a very tight budget and I don't want to pay too much or pay for something that doesn't need to be done to service tech. I am a commercial printing so i am technically oriented & any help would be greatly appreciated! Also I would like to get a pdf copy of the service manual & the full operation/setup manual (all it came with was a copying guide). Thanks for any help!
Registration Issue & UNDO service mode 1 setting
I fixed the service mode problem but not the registration issue
The tech I talked to earlier today had me clear MMI in the service mode 1 menu. I checked the IMG-CONT setting which was at 0. I reset it to 3 and rebooted the machine, the PRINT tab is back on the screen...YES I AM GOOD!!!
Anyway I still need some help with the registration problemThanks,
John M
DPS
Senior Field Technician -
Screwtape.Comment
All good suggestions so far but the one thing I do first with this prob is do a QUICK auto grad adjustment. Dont do the full grad adj but the quick one will sometimes snap the reg back into focus. It lays a different set of patches down that sometimes aligns the lasers automatically. If that has no effect then next would be a DCon clr.
good luckComment
Printing out the P-Print BEFORE doing any clearing or settings changing.
Many good suggestions being offered here,,, but the first step to NOT overlook, is the importance of printing out the P-Print BEFORE doing any clearing or settings changing. We techs take this for granted, but our friend here has said that he is not a technician, especially not one trained on this box. Hopefully this copier arrived with a P-print tucked away somewhere.
To initiate the print: service mode > copier > function > misc-p > P-Print
This step should be taken before clearing, otherwise you will get a printout of factory baseline specs before the machine has been tweaked prior to shipment.
Another physical thing to check/replace, is the drive gear on the ITB drive roller, the cluster & driven gear on the copier itself. A little play in the ITB gear sets up the same scenario as the dirty belt and rollers.
FG6-9662-000 swing gear asm
FU3-0546-000 42t gear
FU3-0266-040 gear"Once a King, always a King, but once a Knight is enough!"
thanks for all the suggestions, i will give them a try. To clarify, I am a offset printing press tech not a copier tech but I am tech savvy in general. thanks for the help I will repost with my results.
Also if anybody has a Canon service manual for this C3220 I would like to get a copy, pdf form would be fine.
Thanks,
JohnThanks,
John M
DPS
Senior Field TechnicianComment
