Remove paper from output tray
  • V-P
    • Apr 2011
    • 679
    Imagepress C750 with Finisher removed.
    So just the machine running.
    After a few printed jobs - the message appears: "Remove paper from output tray"
    The only way around is to turn off / on the machine.
    I already changed
    *Level2" Copier/Option/User
    TRAY-FLL from 0-1
    TRY-STP from 0-1
    Ideas ?
    Thnx
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Remove paper from output tray
    Try to clear the finisher information which is stored in the Main Controller. COPIER-FUNCTION-CLEAR-FIN MCON
    After execution, reset the Delivery Tray again in Settings/Registration> Function Settings>Common> Paper Output Settings> Output Tray Settings.
    • zoraldinho
      • Mar 2008
      • 5015
      Any update?
      • V-P
        • Apr 2011
        • 679
        Hi Z
        I tried for a while but the message continued. I connected the finisher back again.
        The problem with the finisher is that some media, like labels or high glossy will trigger the 1124 jam.
        that is why I disconnected
        thnx
