C3325i - Does a developer replacement require replacement of another consumable too?
  • oreoh
    • May 2022
    • 9
    Hi guys,
    So I was having issues with my C3325i / C3320F last night and one of the guys helped out here. Working great.
    I recently replaced the developer under the black toner in the printer and today while browsing the forum, I read this post in which a forum member replaced a drum unit (mine is a developer unit) and was suggested to follow through with a blade replacement too.
    I initially called a Canon Technician to diagnose the machine and provide a solution, in which he recommended replacement of the developer unit and the ADF maintenance kit consumable. I have since done both and now I have no white lines on my prints. Now out of curiosity (paranoia really), should I replace any other consumable along with the installation of the developer unit?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: C3325i - Does a developer replacement require replacement of another consumable t
    It is not necessary if the drum is in good condition.
    • HUYNH HUU HOANG
      • Jun 2022
      • 6
      Originally posted by oreoh
      Hi guys,
      https://www.youtube.com/channel/UCaEwLuLFdeXkqHOWKMoaIBQ
