Add Lan Card in to my Canon IR 6570 Mainboard
  • 813200217
    • Oct 2014
    • 53
    I'm not technicin just an end user
    One day, suddenly I cannot print the document via Canon Ir 6570...
    The step i use:
    1. check the lan cable.. i already sure there is no problem
    2. using the same lan cable, plug it into another Canon IR, it work
    So, it think that the lan port is the problem
    Can I buy and plug another lan card into Ir6570 mainboard
    Is The Canon IR 6570 mainboard support external Lan Card?
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: Add Lan Card in to my Canon IR 6570 Mainboard
    No.
    You must use the appropriate Canon part.
