Universal Login Manager, the machines are not becoming Available on Usage tracker
  • Luis
    • Aug 2017
    • 18
    [Misc] Universal Login Manager, the machines are not becoming Available on Usage tracker
    Hi,
    im trying to generate a reports on ULM(Usage Tracker) but the machines are not becoming available, i was tryng to create a certificate but to im strungling.
  • giogi
    Engineer senior
    • Jan 2016
    • 181
    Re: Universal Login Manager, the machines are not becoming Available on Usage tracker
    maybe browser problem?
    try change it
    "Knowledge is a source, but unfortunately ignorance is a sea."
    • Luis
      • Aug 2017
      • 18
      tried around 4 browsers
      • giogi
        Engineer senior
        • Jan 2016
        • 181
        Problem:
        Adobe announced they will stop distributing and updating Flash Player after (EOL) December 31, 2020:
        This has an impact on the Import button which won't be showed on the ULM Tracker web page:
        ULM Usage Tracker
        Improvement:
        Switch the ULM Tracker web to HTML5 file access.
        • errorau
          • May 2011
          • 4
          Try to use firefox
          • Luis
            • Aug 2017
            • 18
            Thank you
