Canon IRAC7565i Error
  • Copybox
    • Sep 2020
    • 59
    [Error Code] Canon IRAC7565i Error
    Got an error code e000066-0001 machine peforming flawlessy beforehand! What does this code indicate and can it be cleared??
    Cheers
  • 20 year tech
    • May 2014
    • 577
    Re: Canon IRAC7565i Error
    e066 is a pre transfer wire cleaning error. the cleaner is probably hung up, remove the pre transfer charge assembly and make sure the cleaner moves freely.
    • Copybox
      • Sep 2020
      • 59
      Thats cool, so do I need to throw any new parts at it??
      • 20 year tech
        • May 2014
        • 577
        If the cleaner keeps hanging up yes change the charge assembly. also check the connector for the cleaner motor.
        • Copybox
          • Sep 2020
          • 59
          First error - so yes will try that.
          Thanks again!
          • khaled_abosere3@yahoo.com
            Head technical support
            • Mar 2012
            • 170
            you can set w-cln-ph in service mode to 0
