Canon iR ADV C5535i, Error code E025-0251
  • OceanLin
    • Jul 2022
    • 4
    [Error Code] Canon iR ADV C5535i, Error code E025-0251
    Hi All,
    I got a problem with CN C5535i, which is the error code "E025-0251", I've checked the SM that is Magenta ATR sensor problem.
    Here is what I've been done, replace a new developer unit, it works at beginning, but after about 6 or 7K prints that happen again.
    I've check Drum unit and DV unit that is no broken or damage, also I've check service mode the "DEN-M" is -3.40% and "SGNL-M" is 253, all looks different than the other three.
    Any suggestions or assistance will be grateful, thanks.
  • giogi
    Engineer senior
    • Jan 2016
    • 181
    Re: Canon iR ADV C5535i, Error code E025-0251
    after replacing the development unit, did you run the INIT?
    "Knowledge is a source, but unfortunately ignorance is a sea."
    • OceanLin
      • Jul 2022
      • 4
      Yes, I did, but the value still the same and the error didn't recover.
      • nicknt82
        • Nov 2011
        • 155
        Originally posted by OceanLin
        Hi All,
        This code doesn't relate to developer. Toner bottle is turned by motor, this motor be locked and can't turn as normal than code will appear.
        • OceanLin
          • Jul 2022
          • 4
          I've try to swap Cyan and Magenta motor, It doesn't work also, both of these motors rotate well and no damage.
          • nicknt82
            • Nov 2011
            • 155
            Have you checked hopper? Do it has toner? Pour toner inside hopper out then toner bottle must be turn. Check If bottle toner turn but no toner fill in hopper or not?
            • jalaoly
              • Jul 2014
              • 10
              Hi,
              As say Nicknt82,I have the same pb and i change the hopper assy color to resolve it
