change boot rom with sst
  • Momolio
    • Mar 2009
    • 30
    can i change the boot rom from c to n with sst?
    please anyone help me...
  • xcopytech
    • Aug 2006
    • 1794
    NO
    • SCREWTAPE
      • Jun 2025
      What model?
      • smiley
        • Aug 2008
        • 615
        hi guys can you help me change irc3200c to irc3200n.please because if i try to upgrade the boot rom i says error0013 on sst.
        there is no glory without sacrifice
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          Boot roms can only be updated with the correct version, type c's need type c update versions, and n's need type n versions. There is no way to convert from c to n.
          I assume the error occurs, because the tool reads what kind of rom you are trying to write to, and if there is a conflict between c rom and n software, or vice versa, the software will error out. You will have to shop around to find a real n rom.
          Happy hunting!
          • zero Canon
            it can be done ,-whether with sst or not.
            pm canonphotocopiers@gmail.com
            • SCREWTAPE
              • Jun 2025
              It can be done if you have the proper utilities, like a boot rom chip burner. This is why Canon started the LMS. We know that they are guys out there doing it. The only machine that I remember using two boot rom chips was the iR5000s, One had one slot to boot up the unit and then the other slot was to upgrade the chip to a network chip. If you are working on this model then the answer will be yes, and this can be done with the SST. You might have to find a earlier version SST.
              • Momolio
                • Mar 2009
                • 30
                ok i see... but i'm sorry to ask the question again...
                i have a version of sst 4.04 but every a want to connect to machine.
                the sst got error like this.
                "path error/075"
                what is that? can u help me again please...
                • smiley
                  • Aug 2008
                  • 615
                  hi guys where can i buy the bootrom chip burner?
                  • Amstel
                    • Jun 2025
                    Error 075
                    "path error/075"
                    Error 075 Download result. Checksum obtained after writing operation did not match the correct value.
                    • Amstel
                      • Jun 2025
                      I can help.
                      How are you doing upgrade? Describe.
                      • smiley
                        • Aug 2008
                        • 615
                        Originally posted by Ams
                        I can help.
                        yup im trying to update a c boot rom into n boot rom but the error appeare.
                        • SCREWTAPE
                          • Jun 2025
                          When registering firmware for the iRC3220 there is no distinction between N or C version in the Service Support Tool. When you flash the C3220 simply select 'BOOT' and begin the flash process, the Service Support Tool is intuitive and will select the proper version automatically.
                          • smiley
                            • Aug 2008
                            • 615
                            thanks for this info screwtape.it means i can change my irc3220c in irc3220n.without using boot rom chip burner?
                            • Amstel
                              • Jun 2025
                              Need a working "N" BOOTROM
                              When you update BOOTROM "N" after verivication, need to remove "N" and insert "C" BOOTROM
