iRADVC 5240 error code E102-0101
  • Blues Guy
    • Aug 2009
    • 216
    Good day everyone,
    I have a unit iRADVC 5240 with error code E102-0101. Have swap with a working condition DC controller P.C.B
    and clean the laser unit polygon mirror still same problem.
    Any other parts to check around ? Thank you in advance if any of you can enlighten me this problem what else
    to check.
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: iRADVC 5240 error code E102-0101
    First try swapping the yellow/magenta laser unit with the cyan/black laser unit and see if the error changes to E102-0301 to see if laser unit is faulty. Next could be wire harness p/n: FM4-9444
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
