code E747-3f02 imagepress C1+ it gets ready and does not print or copy the lamp
  • JOSEPH2023
    • Oct 2020
    • 9
    GOOD NIGHT
    I have a problem with an imagepress C1+ the error code E0747-3F02 is coming out
    I have cleaned the cards connected to the main PCB, I erased the code and it gets ready but when I want to print or make copies it only makes a sound and does not turn on the lamp and does nothing the same when printing the data arrives but it does not print anything the data is lost
    it doesn't do anything or print or copy your help please
  • wcanonw
    • Aug 2014
    • 404
    • JOSEPH2023
      • Oct 2020
      • 9
      Re: code E747-3f02 imagepress C1+ it gets ready and does not print or copy the lamp
      No, I still have that problem with the IP C1+
      • wcanonw
        • Aug 2014
        • 404
        Hello, how does the problem start in your case?
        The machine already had the error code or the error code started when you cleaned the main card unit.
        you can specify how to clean the cards
