- ...the display is distorted, as if it were affected by an interference, (I tried to share photos but I can't, any tips about it)video_9vAZ45Zc.mp4_snapshot_00.01_[2022.09.01_15.51.33].jpg
- I changed the entire display and the problem continues,
- (I remember in the old IR7095, on occasions when they had similar problems, they were solved by cleaning and vacuuming both the UR and the cleaning unit internally ) I did it but it still continues.
- Change outlets to rule out electrical noise on the lines, but it is not the solution...
- any ideas? my next route will be to change the complete power source, let's see what happens
IRA 6055 distorted display
[Electrical] IRA 6055 distorted display
Re: IRA 6055 distorted display
Assuming all connections are good, I would try MainController 1IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
