Hi all,
I have an imagepress C800 that is giving me the above error.
I have done the following:
Still no resolve in the error though
The client has another C800 that was down because of various other parts needing replacement so I took the whole ITB unit from the above machine and it worked for some time. Did +/-1500 pages and then the same error popped up. Anyone faced a similar problem before?
Would really appreciate some help...Thanks
- Cleaned ALL the patch sensors although it only points to Magenta
- Checked the M drum and developer units - they're OK
- Replaced all the periodically replaced parts in the ITB unit
- Swapped the Registration Driver PCB from a known working machine
