E0000-75-0103/ IR advance C5250
  • copycart
    • May 2009
    • 97
    I have this code on a C5250. I have checked the ITB unit and cleaned the rollers that the belt rides on and reversed the belt. My ITB values were 548-564. I adjusted the bracket on the ITB unit and was able to get values 398-564, still out of range, so I tried adjusting a bit more and I keep getting the the error code. I have ordered an new ITB unit and found a MOD kit in Texas. I was wondering if the ITB unit might do the job by itself. I
    turn the IBT sub pressure release lever to the up position before removing the belt unit and put in the down arrow position after reinstalling and have noticed that it reverts back to the up position.
  • rspicer
    • Oct 2015
    • 97
    Re: E0000-75-0103/ IR advance C5250
    The frames on those ITB units weaken over time and consistently cause e75 errors. The new ITB unit should have the mod kit and should take care of the problem. Make sure you perform the ITB-INIT after installing it to confirm it isn't going to wander.
    • copycart
      • May 2009
      • 97
      Am I correct on the position of the release cam. Arrow in the up position to release the pressure on the belt unit and the down position after installing the new belt unit
      • MerfsCopyPlus
        • Apr 2019
        • 2
        level the machine, using the leveling feet. theres a procedure that comes with the ITB mod kit
