Canon IR1025if Jamming at Drum
  • Will
    • Jun 2007
    • 171
    Cann IR1025if jams out of both paper trays and bypass tray always crumbles up just under the drum unit.
  • Brian8506
    • 1665
    Re: Canon IR1025if Jamming at Drum
    Usually means the drum isn't in properly. Take out and reinstall firmly. I assume it's not getting past the drum and partially into the fuser
    • Will
      • Jun 2007
      • 171
      Thanks, but have already reseated drum several times without any success. Not only that I can see after removing side cover that the drum is engaging with the drive clutch and gear train.
      • Brian8506
        • 1665
        Maybe transfer section not properly engaged with the sector gear on front frame. I think that model uses that. I know the MF version machine did
