Canon c850 skewing image on second side
  • dave36data
    • Jul 2018
    • 16
    Problem with an imagepress c850 which is skewing/ rotating image only on second side. 2.jpg1.jpg
    I have tried to set up using service manual and also the reference guide that canon produced regarding image setup, but to no avail.
    first side (which is the second photo) is spot on, but no matter what I do or adjust the image still remains skewed.
    This occurs out of all cassettes and and tried different stock. i have also tried increasing the second side reg loop which also didnt work.
    the photos show number 1 second side and number 2 first side
    Anyone any ideas, or come across this issue - the machine has done about 8 million prints
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    Re: Canon c850 skewing image on second side
    Originally posted by dave36data
    Problem with an imagepress c850 which is skewing/ rotating image only on second side. [ATTACH=CONFIG]54907[/ATTACH][ATTACH=CONFIG]54906[/ATTACH]
    There could be poor alignement of the rollers on the duplex unit,check the springs and tensions in the duplex.
    • dave36data
      • Jul 2018
      • 16
      thanks, just been advised that there is a canon bulletin for the c800 where it says to grease the reverse driven rollers, so will check that at the same time.
      • wcanonw
        • Aug 2014
        • 404
        Hello, before this problem appears, have they changed any response related to the duplex unit?
        • dave36data
          • Jul 2018
          • 16
          Nothing has changed in the duplex, and whatever setting we try it seems to still skew the same amount
          • wcanonw
            • Aug 2014
            • 404
            Hello, your problem is not something that you have to move some value through the service mode, your problem is something mechanical that you have to see in detail
            • wcanonw
              • Aug 2014
              • 404
              check the duplex if it is that the paper at one end is pressing it is strong and at the other end the pressure is weak, which makes the sheet enter the register deflected, when it is the duplex.
              the images that I will send you are of a c7065 but it should be something similar with a c800
              • wcanonw
                • Aug 2014
                • 404
                As I say, you have to see the route of the path of the paper when it is in duplex, here I send you other photos, you also have to see the guides or the gate is putting bad pressure on the paper or there is something that causes the paper to deviate when it is in duplex.
                • wcanonw
                  • Aug 2014
                  • 404
                  this is the paper path
                  • wcanonw
                    • Aug 2014
                    • 404
                    • Hishamawada
                      • 174
                      Hello , first of all how much is the skew on the back side ? I need values/ photos ? Is the skew have fixed values or random ?
                      Is it an issue on all type of papers ? .
                      In my opinion your problem is way far from where you are searching.
                      Answer my questions to be able to help you.
                      Best regards
                      Sent from my M2101K6I using Tapatalk
                      • dave36data
                        • Jul 2018
                        • 16
                        • Hishamawada
                          • 174
                          Is the skew fixed or random ?
                          Can you send me pictures of the rollers of the registration unit .
                          • wcanonw
                            • Aug 2014
                            • 404
                            IF YOU COULD EXCHANGE THIS PART FIXING/FEEDING ASSEMBLY
                            • Ingranaggio_rotto
                              • Oct 2010
                              • 274
                              With 8 million prints, the entire duplex group and the inversion group must be overhauled.
                              Guides included.
                              Is the paper cut perfectly orthogonally?
