IPF-6410s Error code 03800500-2F40
  • uclbph
    • Jul 2011
    • 34
    [Error Code] IPF-6410s Error code 03800500-2F40
    1. when power up the machine replenish ink and ended with erro rcode 03800500-2F40. the service manual suggests non-ejection has been detected for all nozzles of all colors.
    2. when power up through service mode and nozzle check all nozzle are firing OK. attaching here the image
    what to do any suggestion ?
  • wcanonw
    • Aug 2014
    • 404
    Re: IPF-6410s Error code 03800500-2F40
    it seems that the nozzles of the magenta color (R) are clogged.
    You have already performed the head cleaning manually or through the cleaning option in the plotter menu
    • uclbph
      • Jul 2011
      • 34
      The machine give error code 03800500-2F40 in normal mode and does not operate.
      • comfab
        • Mar 2023
        • 1
        hello uclbph
        did you manage to fix the hardware error 03800500-2F40?
        if yes, how did you proceed
        with my thanks
