canon c5240a error code e227-0101
  • acsolutions
    • Jun 2010
    • 519
    Hello, error code relates to possible reader controller.
    Pulled out the meter and it's not functioning. I suspect power supply or relay b
    It also shows the front door is open. I will probably pull some boards before going back
    To customer location. I'll be returning with a power supply, relay and reader controller as well as a functional volt meter. Any suggestions? Thanks
  • wcanonw
    • Aug 2014
    • 404
    Re: canon c5240a error code e227-0101
    E227 0101 04 Title Power supply (24V) error
    Description 24V port error when the power of DF Unit is turned ON
    Remedy 1. Turn OFF and then ON the power.■
    2. Check the connection between Reader and Printer,
    and check that the Cable is not open-circuit. ■
    3. Check the 24V port of the Reader Controller PCB and
    DF Driver PCB. ■
    4. Check the power supply and Relay PCB on the Printer
    side. ■
    5. Replace the Reader Controller PCB and DF Driver
    PCB
