Canon C5030i Print jobs do not want to be printed
  • jimmydenhaag
    • Oct 2022
    • 18
    Hello everyone,
    I have a problem with a Canon C5030i.
    I have tried to installing both drivers; the UFR and PCL driver.
    Only when jobs are sent to the printer, the machine will receive them, only they will not be printed!
    Printing from a USB disk or a check report from the device itself is no problem.
    What's the problem here? Does anyone recognize this?
    I get code NG #865, who recognizes this?
    I can't get it resolved.....
    Thank you!
  • wcanonw
    • Aug 2014
    • 404
    Re: Canon C5030i Print jobs do not want to be printed
    Originally posted by jimmydenhaag
    Hello everyone,
    Thank you!
    Hello, the IP address of the printer and the computer is correctly configured.
    If it is well configured in the explorer or browser (google) of your computer, where you put the address of the page, delete it and enter the ip address of the printer, it will link you to the page of the printer
    let you know if it could be linked, send photos
    • jimmydenhaag
      • Oct 2022
      • 18
      I can reach the printer's page just fine, that's not the problem. It is also all set up correctly from an IP-technical point of view. I am missing something (possibly in copier mode).
      I can't figure it out, someone who has experience with these machines should recognize this I think. I get code #865 NG as result after printing.
      • Brad6784
        • Mar 2015
        • 78
        Hi,
        Is job account turned on? This will give your exact symptoms if my memory serves me correctly!
        Good luck.
        • diedux
          • Jan 2017
          • 124
          • nicknt82
            • Nov 2011
            • 155
            Hello everyone,
            Thank you!
            Check Department ID setting. Do it turn ON?
            If setting <Allow Printer Jobs with Unknown IDs> was OFF. You can't print if you don't have ID
            • 20 year tech
              • May 2014
              • 577
              Check to see if restrict printer jobs is set to on, Settings and registration>Function settings>Printer>Restrict printer jobs. set it to off if it is on.
              • jimmydenhaag
                • Oct 2022
                • 18
                Hi everyone, I've checked all of the above and adjusted where possible, rebooted the machine but it didn't help unfortunately.
                I'm missing a little thing somewhere that should be the solution....
                • wcanonw
                  • Aug 2014
                  • 404
                  Hello, are you just trying to install the printer to print? Before the printer worked normally, could you make prints?
                  • wcanonw
                    • Aug 2014
                    • 404
                    What page are you downloading the driver from? If you have the driver on the CD that comes with the printer when it is purchased new. go to canon europe or canon usa and download the latest driver that is compatible with the operating system of your computer, in the list of drivers you must download UFR2 LT
                    • nicknt82
                      • Nov 2011
                      • 155
                      Hello everyone,
                      Thank you!
                      #865
                      Cause The functions related to job execution are restricted.
                      Remedy Contact your System Manager.
                      You can output configure pages (user data list) from copier and capture your driver then everyone can help you
                      • jimmydenhaag
                        • Oct 2022
                        • 18
                        The driver should be correct, I've tried both PCL and UFR. Both no effect!
                        Downloaded from Canon website itself.
                        • jimmydenhaag
                          • Oct 2022
                          • 18
                          Originally posted by nicknt82
                          #865
                          I have added the log file. See attached. Thanks!
                          OUTPUT C5030i.pdf
                          • wcanonw
                            • Aug 2014
                            • 404
                            [ATTACH]55427[/ATTACH]
                            ipv6 settings
                            ipv4 primary server 0. 0. 0. 0.
                            • wcanonw
                              • Aug 2014
                              • 404
                              check photo in spanish
