IR C2225 tray 1 lift gear p/n needed
  • copiertec
    • Jan 2016
    • 2211
    We have a Canon IR C2225 and the tray 1 lift gear is broken. What is the p/n?Canon IR C2225 paper tray.jpg
  • fchu5959
    Field Engineer
    • Jun 2010
    • 100
    Re: IR C2225 tray 1 lift gear p/n needed
    [ATTACH=CONFIG]55493[/ATTACH]
    Gear 8T------FE4-3901-000
    If my memory is good,the new type of gear is made of metal alloy
    The IRC 20/22xx series are the worst machines of the Advance series.
    Lots of issues such as E020-xxxx,E074,jam from the lst pick up assy,color displacement,E001 and noise from the fixing assy and so on.....
    Good luck.
    • copiertec
      • Jan 2016
      • 2211
      Good luck.
      Yes, it has 8 teeth, thank you. Sounds like the machine will be a money maker for our sales dept.
