Hello, I have a problem with a Canon Advance 8105 photocopier. It has an error 733. A
  • Dada Alla
    • Nov 2022
    • 2
    Hello, I have a problem with a Canon Advance 8105 photocopier. It has an error 733. Also, the motors do not work at all. Is there a solution for it? Where is the defect and how is it repaired?
  • jimmydenhaag
    • Oct 2022
    • 18
    Re: Hello, I have a problem with a Canon Advance 8105 photocopier. It has an error 73
    • Code: E733 0000
    • Description:Printer communication error
    • Causes:Communication error between the Engine Controller PCB and the Main Controller PCB occurred.
    • Remedy:1. Check the connection of connector between the Engine Controller PCB and the Main Controller PCB. 2. Install the set of the controller firmware. 3. Replace the Main Controller PCB. 4. Replace the Engine Controller PCB.
