This is my problem. I have C800 that lately when I send over jobs if I don't have the paper loaded that it needs then instead of sending it over and beeping saying change paper, it doesn't send the job over, it stays on the fiery and says change paper on that side. If I restart the fiery then it works, then if I send something else that is not been updated on the fiery as far as Paper size and weight attributes it will do it again. I'm not sure what to try other than maybe reloading the software on the fiery. That seems like it is a last fix idea. Has anyone else encountered this type of issue? Thanks
update: if i send a job over it will sit and process and look for required paper for 5 minutes then suspend the job. if i tell it to rush job it sends over and runs if i wait until 5 minutes it will suspend the job then i have to print again and select rush print. this seems like an issue with the enable mismatch button but as far as i know i have not turn that on. Maybe i should turn it on then reboot the fiery and then turn it off and reboot the fiery.
Has anyone else had a similar issue?
