IRA6265 white lines
  • Nelson Trident
    • Jun 2021
    • 8
    IRA6265 white lines
    Good morning everyone. Can someone simply throw me a few words on how to solve this problem please.
    It only happen when doing photocopy. There is no problem on P-Print sample.
    I changed scanner unit with the white flat cable and reader PCB but the problem still the same.
  • Canuck
    Tech Specialist
    • 1713
    Re: IRA6265 white lines
    Copies from glass or through document feeder? Remove the large glass, flip it over and make sure that the white strip is pure white all the way across. I've seen it lift under an area from customer getting it wet with Windex, so shading correction will be wrong in dark areas, csusing a light area when scanning
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      looks like laser glass is dirty
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • Canuck
        Tech Specialist
        • 1713
        He said printing is fine...only happens when copying. If it was a dirty laser glass, prints would show the problem also
        • Nelson Trident
          • Jun 2021
          • 8
          Sorry for late reply. The problem solve. Changed platern glass. The white strip on the left side of platen glass almost came off.
