Canon ir1133if scan error "#806"
  • Printer77
    • Sep 2019
    • 58
    [Error Code] Canon ir1133if scan error "#806"
    Scan to send on canon ir1133if won't send scanned file and prints TX error "#806". That error happens only on windows 7 but not on windows 10. I checked host, folder name, username, password and everything is fine.
  • ElZero
    • Sep 2021
    • 24
    Re: Canon ir1133if scan error "#806"
    First, i would try to access the folder from another PC. Also would check the security settings in the folder properties, especially the owner. sometimes things get messed up, if the folder is in a user's directory (desktop, documents ... ) but the user in the smb connection is not the owner.
    • Printer77
      • Sep 2019
      • 58
      I tried to put folder in (C:\) but it's still error "#806". All permissions are good.
      • ElZero
        • Sep 2021
        • 24
        As far as I remember iR1133 does not support smb v2/3...
        maybe you got to enable smb v1 at the win 7 client. smb1 is usually turned off also at windows 10. and: it's turned off because of serious security issues...
