Canon IR ADV 4225 - unable to install firmware on HDD
  • cvishruth
    • Jan 2023
    • 2
    Hi,
    I have a fully working canon IR ADV 4225 , and a USB drive with the firmware loaded , I have been trying to flash the firmware to a new HDD (want to use this on a different machine as its HDD is broken) , the firmware loading process gets stopped at 99% and shows a checksum error post which I get E748-2012 error which my engineer was able to fix by doing something with the flash PCB. But when I try to flash the firmware to a new HDD again , I get the same errors. Can someone tell me what's going wrong?
    Below are the images of the error.
    WhatsApp Image 2023-01-03 at 3.11.21 PM.jpgWhatsApp Image 2023-01-03 at 3.11.24 PM.jpg
  • ADV COPIER
    Pemain
    • Nov 2022
    • 241
    Re: Canon IR ADV 4225 - unable to install firmware on HDD
    Originally posted by cvishruth
    Hi,
    [ATTACH=CONFIG]56149[/ATTACH][ATTACH=CONFIG]56150[/ATTACH]
    your firmware is broken
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • cvishruth
      • Jan 2023
      • 2
      Are you sure a 100% ? if yes , can you please share the firmware
      cvishruth@gmail.com
