Jammming with DADF type G1
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 171
    [Jamming] Jammming with DADF type G1
    Dears all:
    we face a problem with DADF type G1 when jamming occur the jam won't clear until that restart the machine the jamming codes varies between Jam code 0045 and 0096
    we searched for jam code 0096 in the service manual not found.
    we cleaned all sensors.
    any advice may help us.
  • Brian8506
    • 1664
    Re: Jammming with DADF type G1
    What machine is that on?
      • Mar 2012
      • 171
      Canon IR advance 8285
      • Canuck
        Tech Specialist
        • 1713
        There are 3 or 4 transceiver type sensors with prisms in the feeder. One is failing initialization when you hit start. Manually push a piece of cardstock through the df paper path to push out anything that might be stuck. I've had to replace them a few times. Sometimes blowing them out and initializing them works sometimes, or the prisms fall off. They can be checked in service mode
          • Mar 2012
          • 171
          Thank you for your interest But the feeder working fine for feeding paper as well till jamming happens with the feeder the jamming won't go out until restart the machine.
          And at the end what about jamming code 0096 which in not mentioned in service manual.
          Thanks in advance.
          Sent from my CPH2239 using Tapatalk
            • Mar 2012
            • 171
            [emoji22][emoji22][emoji22][emoji22]
              • Mar 2012
              • 171
              Any suggestions men !
