Canon 8295 jam code 0111
  • bcopier2815
    • Oct 2015
    • 42
    I have an 8295 that gets intermittent jam code 0111. The service manual mentions 0111 DELAY Fixing Outlet Sensor PS52. I have replaced the sensor and it did not help. Anyone come across this error?
    Mike
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 171
    Re: Canon 8295 jam code 0111
    There are many causes that may result to this jam code:
    Frist:
    [Symptom]
    0111 jam occurred and was a consistent jam. The ETB belt and the Transfer High Voltage PCB were replaced but these parts had no effect on this jam.
    • 0111: Fixing Outlet Sensor (PS52) Delay jam
    [Remedy]
    The solution to this issue involved replacing the Fixing Inlet Sensor Flag Assembly, FM1-C082. The original sensor flag had a side that wore out. The original sensor flag on this machine was the old type. Once the Fixing Inlet Sensor Flag Assembly was replaced the 0111 jam stopped.
    followed by pics. old & new
    Second:
    [Symptom]
    0111 jam code is displayed. Please explain details of service mode (Level 2) > COPIER > ADJUST > HV-TR > TR-OFS1 (Adjust transfer target current offset: Plain).
    [Remedy]
    Set the environment (temperature and humidity), feed mode, and Transfer Roller target current offset value in the order from left. When the actual usage status matches to the specified environment and feed mode, the specified offset value is added to the Transfer Roller target current.
    • Environment 0: No specification
      1: Environment 1and 2
      2: Environment 3 to 5
      3: Environment 6 and 7
      4: All environments
    • Feed mode 0: No specification
      1: Cassette/3.5K deck 1-sided
      2: Cassette/3.5K deck 2-sided
      3: Multi-purpose Tray 1-sided
      4: Multi-purpose Tray 2-sided
      5: Large deck 1-sided (only POD Deck Lite)
      6: Large deck 2-sided (only POD Deck Lite)
      7: All modes
    • Transfer Roller target current offset value "-10" to "10"
      Third:
      [Symptom]
      Service mode (Level 2) > COPIER > ADJUST > HV-TR > TR-L-OF1 (Adjust transfer target current offset: Plain) has 2 input locations but which should be entered and adjusted with a value?
      [Remedy]
      Adjust the left value.
      NOTE: The left side is the leading edge transfer target current offset value. The right side is the offset value of leading edge transfer bias output timing.
      Fourth:
    [Symptom]
    When using recycled paper, 0111 jam code is displayed.
    [Remedy]
    • Select service mode (Level 2) > COPIER > Adjust > HV-TR > TR-SP1 (Set transfer target current adjustment: special paper 1), and change to "6". The range of settings is as follows.
      "0": No specification
      "1": Transparency
      "2": Postcard
      "3": Tracing paper
      "4": Bond paper
      "5": Labels
      "6": Recycled paper
      "7": Color paper
      "8": Punched paper
      "9": Tab paper
      "10": Letterhead
    • Select service mode (Level 2) > COPIER > Adjust > HV-TR > TR-L-OF5 (Adjust leading edge transfer target current offset: Special paper 1), and change to "-1".
      • Leading edge transfer target current offset value: "-2" to "10"
      • Offset value of leading edge transfer bias output timing: "0" to "20"
