8070 & 105+ system software...
  • j2980kh
    • Mar 2009
    • 69
    8070 and does 105+ write a same firmware?
  • SCREWTAPE
    • Aug 2025
    Yes..
    • j2980kh
      • Mar 2009
      • 69
      Thank you SCREWTAPE
      • AQBJ8
        • Oct 2008
        • 22
        Thank you SCREWTAPE
        I seem to have 105 + of the
        • Dimacop
          • 43
          hi,
          need canon ir 105+ / 105n firmware.
          thanks .
          robertodemelo@hotmail.com
          • davidj7
            • 1107
            screw: so i can load the 8070 s/ware in 105 without any changes?
            a machine is only as good as your tech : source:screwtape ; the scary one
            • SCREWTAPE
              • Aug 2025
              Only if its a iR105+
              If its a iR105 then you will have to used 8500/105/7200 firmware which is v86.02..
              • davidj7
                • 1107
                thanks screw i have 8500 and 8070 software.I register those with SST and connect to the machine in download mode and then just send it to the machine? will it work? while registering the firmware to SST its shown as 8500 and 8070 firmware not as 105 and 105+
                • nivssluck
                  • May 2008
                  • 228
                  IR9070 and IR105+ is the same. I don't think if it's possible to load the ir8070 system to ir105+.
                  • SCREWTAPE
                    • Aug 2025
                    I believe you can its the same firmware. Check out some of the attachments.
