poor fixing in ir3300
  • AIT MAMEUR
    • Jun 2008
    • 59
    after replacing the film of my fixing unit, i got a poor fing in the copies. please help me.
  • mujibur
    • 53
    coming eny errors code
    • davidj7
      • 1107
      Are you using original canon/compatible toner
      a machine is only as good as your tech : source:screwtape ; the scary one
      • AIT MAMEUR
        • Jun 2008
        • 59
        i am using a compatible toner but i didn't have this problem before.
        • davidj7
          • 1107
          I had the fusing problem when using compatible toner.Now using original canon .No issues
          • zaza
            MECANOGRAPHE
            • Mar 2008
            • 1095
            hi friend
            hi friend technician use the original toner of this canon IR2200_3300
            BEST TECHNICIAN . NICE PEOPLE .
            • AIT MAMEUR
              • Jun 2008
              • 59
              but i didn't have this problems with the other machines since i use the same toner
              • AIT MAMEUR
                • Jun 2008
                • 59
                i am using the same paper with another ir3300 and it's go normally, i think the problem is in the fixing unit because when i change the fixing unit by another one it work but i don't know where??????????????????
                • SCREWTAPE
                  • Aug 2025
                  You don't know where, What!
                  If you swap the fixing ass'y and it works, then its the fixing heater.
                  P# FG6-5712-120-100v
                  FG6-6039-000-120v
                  FG6-6041-000-220v
