Good day to all
I have a unit iradvc5235 when you print a configuration page or print list for counter list the machine will produce a blank copy.
Machine when do PG10 test output there is image CMYK
Try make a copy from scanner if you select only black copy come out result blank but if you select full color the result come out have image.
I have all relevant pcb such as main con 1 &2, DC controller, HVT, both laser unit, itb belt assembly & transfer roller still the same.
Any clue how to solve this problem? Thanks in advance
