front cover open error
  • magesh
    • Apr 2022
    • 26
    [Misc] front cover open error
    HI Everyone,
    My canon c5030 machine getting error display as front cover open even if its closed.
    idk what i need to do..
    herewith i attached the front cover photo. idk anything wrong, i am a beginner idk what to do.
    please help me someone
  • Brian8506
    • 1665
    Re: front cover open error
    Check interlock switch actuator. That machine may share the interlock with the side door. Not sure.
    • magesh
      • Apr 2022
      • 26
      Thank you so much sir, now the front cover open error solved but E000021-0300 Error Appears
      help me on this
      • Brian8506
        • 1665
        help me on this
        Yellow developer motor problem. I would check the coupling gear on the back of the developer unit.
        • Benjamin98
          • Mar 2015
          • 89
          help me on this
          Hi, how did you solve the cover open error? Getting it on a C5240 as well. The actuator looks fine (assuming it's the one on the front cover??)
          • Brian8506
            • 1665
            Front and side door share an actuator. Probably needs reforming
