Canon ir 2535 leeding edge prob
  • KHAN
    • Aug 2006
    • 261
    Hello friends , i have canon ir 2535 having leeding edge problum ,
    please i need help. THANKS
  • Brian8506
    • 1664
    Re: Canon ir 2535 leeding edge prob
    Prints? Copies from Glass? Copies through ADF? Could be registration clutch or clutch in the adf
    • KHAN
      • Aug 2006
      • 261
      Thank you sir for your kind reply, copies from GLASS, i dont have ADF
      • Brian8506
        • 1664
        Sounds like a registration clutch if the lead edge varies.
        • KHAN
          • Aug 2006
          • 261
          No sir the leading edge not varies even I make more than 1000 copies.
          • Brian8506
            • 1664
            Originally posted by KHAN
            No sir the copies not varies even I make more than 1000 copies.
            What problem are you having? If the lead edges off consistently you may just have to make adjustments in service mode
            • subaro
              • Oct 2010
              • 1274
              What exactly is the problem. You have not stated clearly what is wrong with the leading edge. Is it skewed, the margins are to small, big ect. Describe your problem better, so the people can help you better. Right now, I see it is a guess as to what is actually happening.
              • KHAN
                • Aug 2006
                • 261
                Thank you sir, yes it skewed the margins. the print starts from the edge of the paper.
                • Brian8506
                  • 1664
                  Is the image crooked on the paper? If it's just the margins being off check and adjust registration in copier/adjust/feed adj.
                  • KHAN
                    • Aug 2006
                    • 261
                    How can i adjust registration, in USER MODE OR IN SERVICE MODE ?
                    • Brian8506
                      • 1664
                      Service mode on that model is a little challenging. A service manual would help a lot.
