Is Faxing Possible Without the Universal Scan Kit on IRC3200 ??
  • junkiemanxl
    • Dec 2007
    • 49
    Hi all,
    Is faxing possible on machines that do not have the universal scan kit ap1 installed? I'm trying to install a fax board on a machine that does not have the universal scan kit involved and i'm unable to do faxing. It does detect the fax board and the LCD shows the fax option but when i try to fax, there's no action. A slight hang occurs and nothing happens. Store in user inbox is not possible as well. is this due to the absence of the universal scan kit ap1 not being installed?
    Anyone has a solution to this or may know the cause of the fault. please do kindly share your experiences.
    Thx
    Regards:
    JMXL
  • Amstel
    • Aug 2025
    If you need to have a fax, set Resolution Switching Board-A1
    • junkiemanxl
      • Dec 2007
      • 49
      Hi there,
      thanks for the response. where do i find that and have that installed? is it in service mode?
      • Amstel
        • Aug 2025
        Originally posted by junkiemanxl
        Hi there,
        The Resolution Switching Board-A1 PCB must be installed, unfortunately, I do not know whether to buy this card now.
        • junkiemanxl
          • Dec 2007
          • 49
          ic, thx for the advise.
          cheers
