Code E000-0107 Imagepress C8000VP
  • escalante
    • Sep 2018
    • 115
    Good night. Complete primary fusion unit replaced. And I still get the same error. Someone who can give me a help.
    Enviado desde mi Infinix X693 mediante Tapatalk
  • cirujano
    • Jul 2012
    • 7
    Re: Code E000-0107 Imagepress C8000VP
    E000-0107-05 Fixing temperature rising detection error
    Detection Description The temperature of the Primary Fixing Pressure Belt Heater did not reach 17 deg C within 50 sec
    at warm-up rotation.
    After performing the remedy work, go through the following to clear the error: COPIER>
    FUNCTION> CLEAR> ERR.
    Remedy [Related parts] R1.00
    - Harnesses from the Primary Fixing Heater Driver PCB to the Primary Fixing Pressure Belt Heater
    1. Primary Fixing Heater Driver PCB (UN306/J4311P) to Relay Connector (12P) (Unit of
    replacement: CABLE, FIRST FIXING DRAWER)
    2. Relay Connector (12P) to Drawer Unit (J7026D) (Unit of replacement: CABLE, DRAWER, 1)
    3. Drawer Unit (J7026L) to Relay Connector (3P) (Unit of replacement: CABLE, DRAWER, 1)
    4. Relay Connector (3P) to Primary Fixing Pressure Belt Heater (H305/J7628 and J7629) (Unit of
    replacement: CABLE, HEATER)
    - Harnesses from the Primary Fixing Outer Driver PCB to the Primary Fixing Pressure Belt Main
    Thermistor
    1. Primary Fixing Outer Driver PCB (UN304/J4192P) to Drawer Unit (J7026D) (Unit of replacement:
    CABLE, DRAWER, 1)
    2. Drawer Unit (J7026L) to Relay Connector (7P) (Unit of replacement: CABLE, DRAWER, 1)
    3. Relay Connector (7P) to Primary Fixing Pressure Belt Main Thermistor (THM300M/J5402) (Unit
    of replacement: CABLE, THERMISTOR, RIGHT)
    - Harness between the Fixing Duplex Feed Driver PCB (UN311/J4081 and J4082) and the Primary
    Fixing Outer Driver PCB (UN304/J4181P and J4182P) (Unit of replacement: CABLE, FIXING
    DUPLEXING, LEFT)
    - Harness between the DC Controller PCB 1-2 (UN124/J1070, J1071 and J1072) and the Fixing
    Duplex Feed Driver PCB (UN311/J4071WH, J4072WH and J4070) (Unit of replacement: CABLE,
    FIXING DUPLEXING DRAWER)
    - Primary Fixing Pressure Belt Main Thermistor (THM300M)
    - Primary Fixing Pressure Belt Heater (H305)
    - Primary Fixing Heater Driver PCB (UN306) (Unit of replacement: FIXING HEATER DRIVER PCB
    Assembly)
    - Primary Fixing Outer Driver PCB (UN304) (Unit of replacement: FIXING OUTER DRIVER PCB
    Assembly)
    - Fixing Duplex Feed Driver PCB (UN311) (Unit of replacement: FIXING DUPLEX FEED PCB
    Assembly)
    - DC Controller PCB 1-2 (UN124) (Unit of replacement: DC CONTROLLER PCB 1-2 ASSEMBLY)
    [Remedy] Check/replace the related harness/cable, connector and parts.
