C5540 won't boot up
  • repeatcopiers
    • Sep 2008
    • 591
    C5540 won't boot up
    Customer came into the office and C5540 said "Checking the data....Do no turn off the main power. Remaining time 1 minute." It stayed that way for hours, when we arrived, we replaced the hard drive and got an E602-0001. Came back out next day with another hard drive just to make sure our other one wasn't faulty and got the same E602-0001. Put customers original drive back in and got the same Checking the data message, it started out as 100 minutes remaining but very quickly went to 1 minute and stayed that way. I haven't seen this issue on these newer models so was hoping someone could shed some light if they have experienced this before. My first instinct is to replace the Main Controller that the hard drive plugs into, does anyone have any other suggestions?
  • eddy out
    • Oct 2016
    • 359
    Re: C5540 won't boot up
    Unplug the hdd.oh, you did that. Is there a fax board or anything else attached to the main controller?
    • repeatcopiers
      • Sep 2008
      • 591
      No they do not have a fax installed and I don't recall seeing anything else.
      • Brian8506
        • 1664
        Not familiar with that model but when you replaced the HDD did you install new system software?
        • repeatcopiers
          • Sep 2008
          • 591
          The copier gave an E602-0001 with the new hard drives so couldn't do anything. These drives came out of working c5540 units so we know the drives are good.
          • ADV COPIER
            Pemain
            • Nov 2022
            • 248
            replace the HDD and install new firmware
            Let's Drink our Coffee
            WhatsApp +62895325228383
            • eddy out
              • Oct 2016
              • 359
              Format?
              • ADV COPIER
                Pemain
                • Nov 2022
                • 248
                Originally posted by eddy out
                Format?
                yes
                • Brian8506
                  • 1664
                  • repeatcopiers
                    • Sep 2008
                    • 591
                    Thank you, that is nice to know. 26 years in this business and I have always used hard drives from other copiers. Are there any other items that can't be swapped anymore, like the Main Controller?
                    • dekoster
                      • Aug 2012
                      • 84
                      Das ist ein festplattenfehler
                      Neue einsetzen software drauf fertig
                      hatte schon oft das problem
