Iradv 4225 error light keep blinking
  • Blues Guy
    • Aug 2009
    • 216
    Good day to all
    Having a iradv4225 the panel error red light keep blinking. Machine no error code indicates.
    Can't make copy and print report from the machine. Any idea ? Thank you
  • Brian8506
    • 1664
    Re: Iradv 4225 error light keep blinking
    Did you go into system monitor and see if anything is in the print queue?
    • Peter Sim
      • Sep 2008
      • 445
      Originally posted by Blues Guy
      Good day to all
      Try to change panel control board
      • Qwert01
        • Aug 2022
        • 20
        Did you do something on the copier, so it shows, or did it just start? I had a case when I forgot to put the cable back into the connector of the high voltage board. The machine turns on and the light flashes, it does not show any error.
        • adhy
          • Feb 2011
          • 109
          Have you ever removed the drum unit? if you did try to push it in until stuck.
