IRADV 4245 error E804-000
  • Blues Guy
    • Aug 2009
    • 216
    Hi everyone,
    I have a Canon IRADV 4245 giving error code E804-000. It will power OFF automatically if you leave the machine ON.
    I have change the Main Controller, Engine Controller P.C.B, Power supply and cooling fan for power supply
    but still will appear the error code. Every parts change I have enter service mode to clear the error before ON the machine.
    Can anybody enlighten me what else need to check ? Thanks in advance
  • Brian8506
    • 1665
    Re: IRADV 4245 error E804-000
    Originally posted by Blues Guy
    Hi everyone,
    Found this from someone else that had that problem
    In this case, connector J205 on the DC Controller was found to be loose. Reseating connector J205 on the DC Controller resolved the error code.
    • Blues Guy
      • Aug 2009
      • 216
      Finally I replace a Main Controller 2 P.C.B problem solved. Thanks for the input
