IRC6800 display E733-0001 error code
  • kmcopytech
    • Dec 2007
    • 141
    After the Replace HDD and bootROM !
    IRC-6800 show E733-0001 error code...
    Help me!!!
    Thanks........
  • SCREWTAPE
    • Aug 2025
    There is a DDI-P communication error,
    Turn off the main power, and check the connectors to the DC control PCB and the main controller PCB, and check the power supply of the printer; then, turn on the main power.
    Make sure all cables are seated properly. Did this unit have a imagePASS-D1?.
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      Did you have either of the DC controller or Main Controller pcb's out of the machine?
      If so make sure that the connector that joins the two boards is connected securely.
      Also...E733 can be thrown up when there's a dip in power(or brown out) and can usually be solved by cycling the machine(turn the power off/on).
      • rosaro75
        • Mar 2009
        • 87
        if you change mfc or ufr or hdd this error comes. first rerun sst for all including d con.
        • kmcopytech
          • Dec 2007
          • 141
          thank everyone!!!
          No sst and firmware.
          Please Provide help........
          My E-mail: kmcopytech@gmail.com
          • Barcode
            E00733-001 error code
            I had that problem on a iR-2230 after the laser unit being unplugged.
            Just check all memory chips. Remove and replace each.
            Then restart the machine.
            • 11x17
              • Apr 2007
              • 153
              How could you have replaced the hard drive and not had access to sys sftware or the sst?
