Canon GP405 can not use parrarell port
  • phollawat Chaimoonchuen
    • Dec 2007
    • 71
    I use Canon GP405, but can not print work from computer by parrarell port. Please help me and see to attach file.
    Phollawat
  • SCREWTAPE
    Phollawat
    You are saying parrarell port, but the config page is for network printing, parrarell port is sort of like peer to peer which requires a straight connection with parrarell cable. Network connections require an ethernet patch cable, is this what you are using. Plus, are you using the correct print driver.
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      I believe that the parallel port is used only for service support tool to update the firmware. To print it requires the use of the network port.
      • pearlpdy
        • 44
        change the parallel port cable. cable only fault. otherwise use network connection, first u put domain or workgroup name and server name, workgroup name is equal system and copier and put ip address. use crossover network cable
          • Dec 2007
          • 71
          I check agian. Thankyou very much
          Phollawat
          • mrfixit51
            Lead Service Technician
            • 1975
            The parallel port will support printing, that is why it shows enabled in this instance. You do have the ability to turn it off during configuration, but what is the point of doing that? The driver still needs to be properly configured on the pc to do this....
            This is sometimes useful as a troubleshooting tool to see if the ethernet port is bad, if you can still get it to print through the parallel port.
              • Dec 2007
              • 71
              Thankyou very much.
              Phollawat
              • rosaro75
                • Mar 2009
                • 87
                if your parallel cable ok the windows will detect it automatically. also if length is so long it will not work. network port is adviceable to avoid data loss.
                you had port 9100 also. so it is very easy to configure. try network port it will not disappoint you.
                  • Dec 2007
                  • 71
                  I can do it. Thankyou so much.
                  Phollawat
