ir3300 control panel lcd screen
  • bnmand
    • Sep 2008
    • 383
    An IR3300 control panel LCD screen won't turn on. A N Boot ROM and NIC were just put in the machine and when I went to turn it back on the screen so the IR3300 could be put into download mode but it wouldn't turn on. A very brief noise is made and the screen doesn't turn on. Everything else seems to work properly as far as I could check.
    Edit: worked out what the problem is. The N Boot Rom doesn't work. Have checked with Original Boot Rom and N Boot Rom from a working IR3300 machine. Is there anything I can do to try and fix the Rom so it will work?
  • welshman
    Technical Support Manager
    • Oct 2007
    • 91
    Nope the Rom Dead you cant repair it
    Send back to canon for a service replacment
    You can flash them but need the right equipment and software to do it not worth the price for 1 rom
    and its illegal anyway so dont do that option
    • Peter Sim
      • Sep 2008
      • 445
      When you change the bootrom to "N" , you should format your hardisk from "C" to "N" also.
      • bnmand
        • Sep 2008
        • 383
        I know that. But if the ROM doesn't work you can't use the machine let alone get the machine into download mode.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          You don't have a spare rom?
          Lemme see what I can dig up and pop it in the post.
          We've got boxes of used roms at work I'll see if I can find an 'N' rom for you....they usually get bundled up with the print kit but we might get lucky.
          • Peter Sim
            • Sep 2008
            • 445
            Do you have extral "C" bootrom?You can change it to "N" bootrom with the help of sst and 26.44 firmware.
            • bnmand
              • Sep 2008
              • 383
              Really? I thought the "C" bootrom's required special tools to update to n firmware. That is interesting. I guess I prefer to use a boot rom from the print kit just in case the "C" bootrom is needed down the track though I don't expect it will be.
              I'll post back if a replacement boot rom doesn't work.
              • bnmand
                • Sep 2008
                • 383
                Replacement boot rom works fine
                • Peter Sim
                  • Sep 2008
                  • 445
                  That good. Take care
                  • jubest2000
                    charge language
                    how to charge the language ir 2200 need to use english
                    • Peter Sim
                      • Sep 2008
                      • 445
                      Go to Additional Function>Language>On and select the language.
