I am an End User. Canon IR Advance 6055 suddenly can't print. need some improvisation
  • 813200217
    • Oct 2014
    • 51
    Suddenly cannot print.. ping the machine. no reply
    already sure that the ethernet port for Rj45 is broken
    already try to print using the others two ports. and it worked
    but using this kind for printing is not suitable for me..
    i have five computers that connect to wifi.. and the wifi connect to the machine
    using switch hub..(Rj45 cable)
    My technician suggested me to buy a new mainboard.
    It will cost me so much money.
    so I need some advice
    anyone already try this and it works?
  • ADV COPIER
    Pemain
    • Nov 2022
    • 256
    Re: I am an End User. Canon IR Advance 6055 suddenly can't print. need some improvisa
    [ATTACH=CONFIG]58900[/ATTACH]
    you can use usb cable and share printer to network
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • 813200217
      • Oct 2014
      • 51
      Thanks for the solution. i already forget this method because using lan for years.
      Now. i need to buy usb cable 15 meters.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        You will likely never find a USB cable that long.
        You would probably need to have one custom made; very pricey and no guarantees. USB was never made to work over those lengths.
        You would be much better off with an external Ethernet to USB print server, such as this one:
        Amazon.com: HP Jetdirect External Print Server/Internet Connector for USB Printers and Ethernet Networks (J6035A) : Electronics
        That one is a bit expensive. I only picked it as an example.
        • 813200217
          • Oct 2014
          • 51
          already try this "usb 2.0 to Rj45 lan port." in my country it was sold for $5
          (ask the question and answer by my self hahahahaha"
          it didn't work, i ping it and no response.
          or there is something missing that i didn't know.?
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            The USB port you pointed to on the copier was a Type A. It's been quite a few years since I've worked with Canon, but I don't think you can print from there. (It may be for firmware installing, I'm not sure.)
            You need to plug into the USB Type B port above it for printing, if I recall.
            You will need a device such as I mentioned, which will connect to the network (with its own IP settings, of course), and output print data to its USB output port.
            There are no $5 solutions here, sorry.
            • 813200217
              • Oct 2014
              • 51
              Problem solved
              Using this usb cable 10 metres
              install the printer
              share the printer
              it costs me $7
              • ADV COPIER
                Pemain
                • Nov 2022
                • 256
                Problem solved
                [ATTACH=CONFIG]58938[/ATTACH]
                install the printer
                share the printer
                it costs me $7
                good work
