Best Drum Cleaning Blade for 8200 series?
  • techandtrader
    • Jun 2016
    • 335
    FC7-9145-000 CLC and cut the ends down or the Regular one? May be possible waste drive can die under a million....and cause smudges too.
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
  • Glennobrien
    • 9
    Re: Best Drum Cleaning Blade for 8200 series?
    I would always say use original one for device. You can flip these blades and use the other edge when they start getting worn so can potentially double the life of it that way.
    • techandtrader
      • Jun 2016
      • 335
      Best to only flip blades in an emergency. Otherwise always use a new blade!
      • Canuck
        Tech Specialist
        • 1713
        FL3-6291. The proper one for the machine. Run it 500k then flip it to the fresh non-yellowed side, wipe with isopropyl, dust with sterate then away you go.
        • Glennobrien
          • 9
