ARRGGHHH..!!!
Don't you just LOVE weird left of field error codes?
I have a machine that from day one has thrown up an E674-0008 fax pcb error.
It USED to be infrequent...but it's now at the stage where it is in a constant state of error if I leave the fax kit installed....remove the fax and the machine behaves like a champ.
So far I've been given a new fax kit and main controller to try to fix the issue....
I've tried:OLD MAIN CONTROLLER+NEW FAX KIT=N.G
NEW MAIN CONTROLLER+OLD FAX KIT=N.G
NEW MAIN CONTROLLER+NEW FAX KIT=N.G.
As well as reloading/upgrading all system software.
I've ordered a new DC controller today to trial that....as there IS a DC component plug into the fax kit.
For those that don't know what E674-0008 is ..it simply means that you have the wrong model fax kit fitted to the wrong model machine....which is NOT the case here.
