Imagerunner advance C3525 MPS message on disply
  • copyhere
    • May 2009
    • 112
    Hi
    I have this machine showing MPS on the display That I want to be gone. the machine came in with a card reader mounted to the left of the display. I have disconnected it but the MPS still shows. Also I saw something about uniflow somewhere. Does anyone know how to make this go away? Thanks in advance for any help you can give me.
  • alex@wocltd.com
    • 430
    Re: Imagerunner advance C3525 MPS message on disply
    dump the main controller
    • copyhere
      • May 2009
      • 112
      By dump the main controller do you mean clear the main controller in service mode? Also do I have to back up any of the settings before doing that?
      • copyhere
        • May 2009
        • 112
        Re: Imagerunner advance C3525 MPS message on disply Solved
        I solved the problem. thanks to alex for set me in the right direction. I didnt clear the main controller but did compare the settings in service mode to an identical machine and found in service mode level 2/copier/ option /user /meapsafe was set to 1 . I changed to 0 and MPS on screen went away.
        • KenP
          • Aug 2023
          • 9
          Also if you do an MMI clear that should reset any uniflow settings.
