ir advance 4225i netwok printing problem
  • ecmcopier
    • Dec 2010
    • 16
    hi, i have problem with ir 4225 ,when printing the order doesn't reach the machine, but when i turn the machine off and open it again the order start to print, can you help me what is the answer. thanks
    • 30139
    Re: ir advance 4225i netwok printing problem
    Download and install the correct print driver from Canon and uninstall the other one
      • 16374
      You may try clearing the print spooler.
      There are a few ways to do this, but the easiest is probably from the Command Prompt. Open the Start menu, search for "Command Prompt," right-click the option that appears, and choose Run As Administrator. Then paste in the following commands, pressing Enter after each one:
      net stop spooler
      del %systemroot%\System32\spool\PRINTERS\* /Q /F /S
      net start spooler
      With any luck, this will bring your printer back to life and you'll get the document you've been waiting for.
        • 30139
        Plus many other helpful videos
        • ecmcopier
          • Dec 2010
          • 16
          [QUOTE=BillyCarpenter;2458502]You may try clearing the print spooler.
          it dosnt work
          can you please describe it again
            • 30139
            Open the printer que on the PC and delete or cancel the job. You can also stop the print spooler. Just remember to restart the spooler
