iR3570 Lcd display
  • Peter Sim
    • Sep 2008
    • 445
    iR3570 Lcd display
    Hai all,
    I need advice for iR3570 LCD display,alway show"The Default key is corrupted or invalid".I don't know what causes this problem.Thanks.
  • 11x17
    • Apr 2007
    • 153
    Access level 2 service mode
    Functjion
    clear
    ca key
    OK
    power cycle
    • SCREWTAPE
      • Aug 2025
      Originally posted by Peter Sim
      Hai all,
      This happens when you clear the main controller, but you can also correct this in user mode rather than going into service mode.
      )* Go to additional function> system settings> network settings> TCP/IP settings>*** certificate settings 2)* Generate Key3)* Key Name:*Input any name, ie. xxxx4) *Select 1024 as the key length5) *Input the current date as the start date6) *Input an end date with current month and date and the year ending with 2025.7)* Start key generation8)* Then go certificate settings and select Key and Certificate List9) *Highlight the default key and press erase10) *Exit out of system setting and power cycle the copier.
      Take care,
      Screwtape
      • Peter Sim
        • Sep 2008
        • 445
        Take care,
        Screwtape
        Thank you for your infos Screwtape.I solve the display "Default ket" problem.
        • SCREWTAPE
          • Aug 2025
          No problem,
          Take care.
